It is currently Sat Aug 16, 2025 7:05 am
PostPosted: Sun Jul 05, 2015 2:07 pm
Last Name: Orr
Hi I am about to start an all mahogany OM. Can you give me some guidance as to target thickness for the top as a starting point before voicing? in mm if possible!
Cheers, Bob
PostPosted: Sun Jul 05, 2015 8:42 pm
First name: Fred
City: Winnipeg
Recall vaguely that Mahogany might have roughly the same stiffness as Spruce. I did make a 0 sized guitar out of Walnut and I was about 2.1-2.2mm. Also depends on your bracing, thinner top heavier bracing. Not much but it is all I got, good luck.
PostPosted: Mon Jul 06, 2015 5:36 am
.125 in thick is a good place to start
PostPosted: Mon Jul 06, 2015 7:47 am
I've done lots of mahogany tops. I treat them exactly like spruce and they have been very successful that way.
PostPosted: Mon Jul 06, 2015 12:38 pm
Last Name: Orr
Thanks for the input guys, appreciated.
Bob
PostPosted: Mon Jul 06, 2015 1:54 pm
That's what my measurements suggest as well. The mahogany I've looked at has not had much higher Young's modulus along the grain than spruce, so you need to leave it about the same thickness. It tends to be denser than the softwoods, so the top will probably be heavier.
PostPosted: Mon Jul 06, 2015 4:33 pm
Last Name: Reed
City: Stowmarket
State: Suffolk
Zip/Postal Code: IP14 2EX
Country: UK
For my ukuleles, spruce tops are around 2mm and mahogany somewhere between 1.8 and 1.6mm. This is based on flexing the top longitudinally until it feels "right", whatever that means. Intuitively I'd expect a mahogany guitar top to be thinner than a spruce one, but I can't offer any reason why.
You can compensate for a thinner top with heavier bracing, but at some point it will sound more like a banjo than a guitar. Stop thinning before you reach that point :)
Users browsing this forum: pkdz and 31 guests
